Merc 60 EFI Fluctuating motor speed at any speed, air in fuel filter
morke
I've replaced the IAC Valve - no improvement. Also checked and tightened all fuel hose connections up to the filter. It seems to be sucking in air and will gradually drain as the engine runs. If I remove the filter element it stays full, but the engine speed still fluctuates and the engine can sometimes just die.
I have not yet pulled the fuel inlet in the tank to see if it has a problem.
Thanks
Welcome
Folks need the most info possible to help and motor serial numbers are best
morke
Yep. Pulled it out of the water (not easy), took it to the dealer, they had it for two weeks, said it was a cracked spark plug and it was running perfect. Took it back, put it back in the lake (not easy) and it was running a bit better but still speed fluctuates and the thing stalls. Dealer said "just bring it in again" like it was easy. They won't send anyone out, I bought the boat from them last August and I'm pissed off (to put it mildly). I need to get this working by July 4 and I'm not willing to go through the hassle of getting it back to the dealer. I don't trust them for one thing. SO my only choice if I want it running soon is to fix it myself. Shame on Mercury Marine, but unfortunately they are following the trend that customer service is following these days -- there is none.
No expert on OB's (just bought 2 new ones) but might contact Merc customer service to ask why your having issues with the fix? While they may not "want" to acknowledge there is an issue with a dealer, it will be documented there is a problem
