sutor623
- Joined
- May 23, 2011
- 4,089
Hey fellas. I am currently doing a fuel/spark/air overhaul on my 65hp. It is a 1967 4 cylinder. When I checked the spark plug wires for continuity, they are intermittent (when I move the wires around). I suspect either a loose plug boot or wire lead. I have seen kits online where you can make your own spark plug wires. The little screw in end for the older Mercuries are hard to find, but I KNOW that I have seen them in one of these Merc kits. Does anyone have an idea of where I can find these kits? Can these ends be re-used if I just get a standard set of wires and plugs? I am thinking about welding the ends onto a standard ignition wire.I dont want to but a used set of wires off ebay because I do not think that will solve my problem. Thanks!
