Merc 650 stuck in forward
Mnace01
I have a '75 Mercury 650 that I recently purchased and replaced the impeller. I put the engine in forward before removing the lower end, but when putting the lower end back on I shifted it into neutral to get the lower end to slide all the way up. Now neutral is forward. How to I get this solved now? I have dropped the lower numerous times and tried different forward to reverse to neutral combinations but it seems to just be stuck in forward, now I have no idea what is going on.
Re: Merc 650 stuck in forward
Drop the gearcase. Set the gearcase to neutral. it will click into and stay in neutral. Now set merControl to neutral and reassemble.
Mnace01
When I drop the lower unit how do i set it to neutral? This is my first outboard, so I am kind of learning on the fly.
Gomer50
With a pair off pliers (be carefull not to damage the splines) rotate the shift shaft (click) so when the prop spins freely both ways thats neutral.
Turn the shift shaft CCW to get to neutral.
