Merc 7.5 tell tail leaking slowly
rookiedave
Hi,
Just put my 2nd impeller in today. (cooked the first one) This time it went in so much better. I fired it up and it ran great. A little smokie but it sounded very strong and ran a long time 10 min before I shut it down. I ran it at idle and at fast rmp. it did not even skip one time. Took the cover off and touched the "block" a little warm but not scalding. Only question is the pee hole does not have more than a trickle of water coming out of it. This time I know, that the impeller is installed correctly. What should I do next?
Thankx
dave
I think that water first squirted out tell tail and then began to trickle.
huntin dawg
Re: Merc 7.5 tell tail leaking slowly
Sounds like a water passage is blocked. Possibly with a piece of the old impeller. You may need to tear it down and clean all of the passages but for now you can try clearing it by flushing the system through the flush port at the top of the exhaust housing.
HD
turtles11756
clear the hole with some wire and see it it starts to run faster
DuckHunterJon
Just for clarification, are you running it on muffs, in a bucket, or on the boat in water? My 3.9 and 6 hp Merc's both act the same way. In a bucket (35 gallon, filled about half way) they will just barely trickle. Motor will be warm, but not scalding. Put them on the boat and take it out, good pee stream out the tell tale, motor is cool to touch. I chalked it up to different pressure (motor depth) in the bucket vs on the boat. Both of these have the pickup under the cav plate, so can't say what they would do with muffs.
rookiedave
Thank you all,
I have it also in a 35 or 40 gallon bbl. I will also rod and flush it out just in case.
snowman48047
I keep a foot long piece of weed-whip plastic on board just for this. I have unclogged that thing a half dozen times. Sand, Clay, weeds, etc...all will clog it so you just get a trickle. Should make no difference whether on muffs, in a bucket or in the lake water should come out the same.
