Merc 700 points setting plate
62cruiserinc
I have a 1962 Merc 700 that I am restoring. I have all the parts necessary, including the service manual.
Does anyone have a source for the ignition point synchronizing plate and pointer?
Every procedure I have read uses these two parts to set the dual points.
Is there an alternate procedure without the plate and pointer?
I can't even find a decent picture of one (for a 6-cylinder) that I could photocopy and make my own from.
Thanks
Steve
emckelvy
Re: Merc 700 points setting plate
Attached is a scanned image of the 6-cyl dwell plate, just print & cut it out.
If you have an old busted or bad rotor, you can cut a hunk of wire, bend to suit and screw (or otherwise attach) the wire to the rotor, to serve as a makeshift pointer.
If you don't have that, just wrap a stout piece of wire around the dist. shaft and bend around so it's in the proper position to work as a pointer. OK for limited use, of course if you were doing these all the time you'd want to come up with something a bit easier to use.
Bore a hole in a hunk of wood the same size as the hole in the dwell plate; slip the plate over the distributor and plunk the whole mess down into the hole. Make sure the hole is loose enough so you can turn the distributor as needed. This makes a nice fixture to hold the dist in place while you're adjusting the timing.
Or cut a hole in a cardboard box & rest the distributor in that. Doesn't have to be fancy, just work!
BTW you'll be rotating the pointer/dist shaft CCW to make this adjustment. Which makes sense looking at the dwell plate.
Just remember the important thing about setting up one of these distributors is that the first set of points must have exactly 90 degrees of dwell (i.e. they must open 90 deg after they close); the second set of points must open 60 degrees after the first set opens, regardless of total dwell.
This ensures even firing between cylinders 1-3-5 and 2-4-6. Otherwise the uneven firing can cause vibration and has, in extreme cases, been known to break crankshafts. Tends to put a damper on things when that happens!
When set up right, these babies really purr. Enjoy the Silky-Smooth idle!
I had an old 700E DockBuster on a 13.5' Sea-King runabout back in the 80's and it was a great little rig, the motor never failed to impress the Wannabee's on the beach who were laughing at the old boat/motor until we hit the starter and roared away!!
HTH............ed
62cruiserinc
Thanks for the image of the plate!
Am I correct in assuming the following?:
The homemade wire pointer initial position on the distributor shaft doesn't matter, but the position (on the shaft) must stay constant throughout the setting procedure.
If I remove the distributor from the engine (for convenience of setting the points), then there is no reference to any particular cylinder, I am just setting the two points for dwell and relative to each other. The TDC and timing will be set later when the distributor is put back on the engine.
Thanks again everyone
Steve
