Merc 75/90 ELPTO lower unit bearing cross reference
dandreye
Hi All,
Assuming this inner needle bearing in my spare 90 ELPTO lower unit bearing carrier assembly needs replacing because of the rust:
https://s1.postimg.org/128nm9k3lb/2017-11-02_001.jpg
, how do I cross reference its part number 31-12578T to bearing makers' numbers? (e.g. Koyo, SKF, Timken etc)
Many thanks in advance!
Mercurylips
Take the assembly with you and ask them or call first and hope you get someone knowledgeable on the other end. Good bearing specialists will know what you need assuming they have it in stock.
dandreye
Looks like it's Torrington B-2812 barely visible in the picture (I.D.=1-3/4", width=3/4").... perhaps someone here could confirm.
https://www.picclickimg.com/d/w1600/...er-Bearing.jpg
Aftermarket: Sierra 18-1113, GLM 22760.
Update: here's entire list of those I managed to cross reference - feel free to amend if you spot any errors:
31-12578T (Torrington B-2812) - Inner bearing carrier NRB
31-30956T (Torrington B-1916) - Outer bearing carrier NRB
31-30894A1 (Timken 25580 & 25520) - Prop shaft TRB
31-30895T (Torrington B-1516) - Prop shaft NRB
31-42677A1 (Timken 15101 & 15245) - Driveshaft TRB (0P215631 & below)
31-883047A1 (Timken NP171520 & NP570491) - Driveshaft TRB (0P215669 & up)
43040T1 (Torrington BH-1812) - Driveshaft NRB
Thread title has been amended accordingly.
