merc 800 /compression too hi?
buddyp
1969 merc 800...stock original powerhead..lubed the cylinders..throttle wfo..all plugs out...comp readings with a known gauge...165..170...165...170..1-4...does this seem hi?
SeaKaye12
Re: merc 800 /compression too hi?
It's a bit high...but the numbers are even. That's the most important thing.
Gauges vary; can you re-take the readings with a different gauge? Are you thinking that you might have some carbon in there?
Chuck
buddyp
Maybe...will treat with mrec power tune after I get it running...firat its replacing all the hoses and maybe top and bot seals..carb kits..ect!
Moody Blue
I've got a '71 Merc 800 and get the same high readings. Not sure if that is typical or not. Have not done a decarb on my motor.
buddyp
Is your motor low hour?
Gomer50
I have got a 1972 Merc 800 and would love to see those high numbers.Mine is a little tired and reads in the 120's +/- 10%.
