EliminatorRider
Thread starter- Joined
- May 21, 2009
- 2
I replaced the seal on my lower unit shift shaft last night along with the water pump impeller and seals. After putting the shift shaft back into the lower unit I noticed it will turn freely. I was under the impression from looking at the manual the shaft should fit down into the shift cam which has splines.
Did something come loose or??? Did the shift cam fall out of place??? When I pulled the shaft retainer out the shift shaft came out with it. I have tried looking into the lower unit but I do not see any kind of splines in the hole that the shift shaft fits into.
Can someone enlighten me? I don't want have to pull the lower unit completely apart to put the shift cam back in place but I will if it has somehow fallen into the lower unit. Thanks.
Rick....
Rick....
