nate_evans79
- Joined
- Oct 30, 2005
- 33
I have a 1978 Merc 900. I got a new starting battery, its a 550 cranking amp battery, I also replaced the starter solenoid. When I charged up the battery, it started fine. took it out for an hour or so, and it ran great. Got home and went to start it to flush the water, and it wouldn't fire up. The starter just turned real slow. I checked the battery on the charger, at it was at about 30% charge. So obviously its not charging off the motor. So I put the battery back on charge, and also took off the stator, and ran new wires to that, as the old ones were pretty corroded. After the battery had reached full charge, I put it back in, and the starter was still turning slowly. I checked the voltage on the battery just sitting there it was 12.68, I checked the voltage at the solenoid it was also 12.6. With the ignition turned to "start" the voltage dropped to 7.8v on the solenoid, and at the starter. The battery read 10.0 volts at "start" possition. I'm a little lost now. I put the jumper cables onto my car, from the boat battery, and tried starting with the car running also, and the starter still turned slowly. I'm just trying to figure out what is at fault here, with out replacing unnessesary things. <br /><br />Is it the battery?, Starter?, or is the new solenoid that I have bad? Or even cables. All wires are new execpt for the power and ground at the starter. <br /><br />Thanks for any help, sorry for the long post.<br />Gotta get this thing running, cause fishing is great right now.<br /><br />Nate.
