merc compression test
izu
Are these numbers OK
#1 125
#2 125
#3 110
#4 130
#5 130
#6 125
Motor running rough
Tadd_P
Re: merc compression test
thats a strong motor you got there those numbers are real good. Try cleaning the carbs out that should do the trick. Also may need to get a new set of plugs too that never hurts
The-Machinist
I would decarb, If you havent already. I got about a 9 percent improvement of compression on my 85 hp johnson. Check the FAQs for the procedure if needed.
