Merc Inline 6 Year
BatDaddy1887
OK fellas....the serial number for my engine is OB110324...photos attached. It's a 115hp. I can't find any references for this serial...especially for correct parts. The original owner was not sure if it was an '87. '88' or an '89. Anybody here have info on this...thanks.
BatDaddy
emckelvy
Re: Merc Inline 6 Year
According to this chart it's an '87:
http://www.maxrules.com/Merc_model_files/115-150.html
Last year for the Inline Six was '88. Your motor has the power-ported pistons/block and will be a very strong runner. Its hp is rated at the prop and so is roughly equivalent to an earlier crankshaft-rated 140hp.
Recommend you go to the engine FAQ at the repair forums root directory and check out the Link and Sync posting, also the decarbonization info.
If you don't know when the impeller was last replaced, be sure to change it before you put the motor in service. Investing in a less-than-$25 part will save you many $$$ in parts and much grief! With all the good info at this forum, you'll be able to replace it yourself and save even more.
Cheers...........ed
BatDaddy1887
Thanks Ed.....it's been two years now for the impeller change so it is due, and yes, this is a great forum for info!
