shipwreck
Thread starter- Joined
- Nov 23, 2006
- 263
1964 mer 650 (65 Hp) lower unit
trying to remove to change water pump.
Where is shift shaft connect that needs to be unhook ?
Can not get the trim tab off, sockets will not fit in casted hole of motor shell?
Is it hex net holds trim tab / use allen wrench to remove or just case of ,motor that make look like that?
I know where all bolts are to be removed from lower to drop it from manual.
