merc manifold vs yammie manifold
ricovw
Just preparing mysef for the future. I have a yamaha 3.0l stern drive. Works great, no issues. The exhaust manifold and riser are getting on the old side. I realize that at some point, i will need to replace it. The exhaust riser is a slightly different bolt pattern than the merc riser. The manifold and riser are BIG money now(yammie). So, i was thinking....i have an exhaust manifold from a 2007 merc 3.0l. Would that bolt up? I had a quick look, and it looks like it would go. Both are GM 181 blocks, so it should bolt up. I could use a merc riser then, nice and cheap i saw at the iboats store, and i would be back in business. I would just have to make sure the exhaust tube would line up. I always do preventative maintenance to my drive and motor, so this is part of it.
Thanks guys... Always helpful.
havasuboatman
Ensign
Re: merc manifold vs yammie manifold
If it will bolt up, you can make it work. Very important to keep the water flow correct.
ENSIGN
Should work,Good luck
