Merc Outdrive stuck shaft
rino
I have a merc outdrive I just got ('78 or '79) and took it off the boat to check; the drive shaft clicks but doesn't turn.<br /><br />The prop and shift seems fine; I can turn the prop by hand both directions in neutral, one direction in forward, other direction in reverse.<br /><br />I can visibly see the shaft turn a tiny amount; it budges the verticle shaft I can see on the upper unit but it doesn't make a complete circle.<br /><br />I would think bad bearings would mean it would be frozen and not turn at all.<br /><br />Where should I start? separate upper and lower, then start at the top?<br /><br />A Clymer manual is on the way in a week. No rush it's my backup project boat.<br /><br />Engine: Merc mcm470 170 HP 224 cid SN: 5479207<br /><br />Out drive: model "R" drive (it has the loop on top and lines on the upper, rounded lower unit) serial number hard to read looks like 5339540 or 5839540.<br /><br />The www.mercruiser.com parts express site doesn't recognise my serial number even with a 0 in front of it; so they say I can't use their site for 7-digit serial numbers pre-1980.
rino
Re: Merc Outdrive stuck shaft
Are there good online sites that have complete exploded views of the Alpha one or "R" outdrive online?<br /><br />I went to a few sites mentioned in other posts but mainly found pictures or ordering info, not "how to assemble" or "disassemble".
FreeBeeTony
Try this site for a diagram.<br /><br />I would remove the top cap of the drive to take a look at the gears.<br /><br />If the drive is removed (which I think it is), you should be able to turn the drive shart by hand.<br />Make sure you turn it clockwise.<br /><br />You will probably need to seperate the upper and lower anyway...
rino
I got the upper and lower separated. The upper turns fine and the gears look fine.<br /><br />There is something stuck in the lower unit. I got the impeller and impeller housing off but the driveshaft doesn't come off by pulling; do I need to push a pin or something to remove it?<br /><br />From the propeller end I removed the prop nut, lock and thrust washers, but the prop is stuck; looks like some kind of sealant other than grease on the shaft. I tried warm soapy water, CLR, rubber mallet, and ball peen hammer to no avail.<br /><br />If I get a prop puller will this give me access to the entire lower unit and gears or do I need to yank the driveshaft off somehow from the top?<br /><br />Thanks!
