merc. prop ??
toocanshan
i have a merc. prop off a 1985 150hp v6. does anyone know if this would fit on my 1978 merc. inline 140. (tower of power) thanks
steelespike
Re: merc. prop ??
It appears to me they will not fit,the V6 is about 14 1/4" diameter the tower is about 13 1/4. While they may physically fit in place I don't think the hub will match the gearcase.
Chris1956
Re: merc. prop ??
To add a little more info. The diameter of the V6 prop exactly matches the OD of the inline six gearcase. It will not recess into the gearcase, as you want it to do. With the correct spacer on top of the thrust hub, you could probably run it. I messed around with that notion one time, since I had a nice Rapture prop off my Alpha 1 OD, and wanted to run it on my Merc 1500. I blew up the 1500(rod issue, not a prop issue), so it became mute.
