Re: Merc Sportjet 120 No spark
Tony - <br />I got mine off (after several hours) using a harmonic balancer puller with grade 8 bolts, penetrating oil, a propane torch, and finally a hammer. It was a real struggle. I tightened the puller as tight as it would go, filled the "well" in the flywheel center with penetrating oil, and let is sit for about an hour. When it still wouldn't budge, I gently heated one quadrant near the center of the flywheel with a propane torch. You don't want to overdo it and cook the stator, but the heat can help draw the penetrating oil into the joint and also, if you heat on one side only, it will tend to expand the diameter of the center hole. After three tries with heating, tightening, oiling, and waiting, it still wasn't coming off. I finally had to hit the top of the puller with a hammer. I used a 2 pound ball peen and hit it rather gently. About 4 blows did it. I understand that you can damage the bearings if you whack it too hard. Good luck!
