merc thunderbolt 95 horse, shifting and starting issues
opalized1
Hung the ole Merc 95 Thunderbolt on my boat for the first time last weekend, and hooked up throttle and shifter controller, a Merc throw back from 1970, wiring is Great motor turned right over, had no gas hooked up yet, so just gave it a quick rotation and stopped.
But upon hooking throttle and shifter up, with controller in neutral, motor wont lift for towing, if I pull shifter forward say 1/4 throttle, then I can lift the motor for towing, shouldn't this motor lift to stow postion when shifter is in neutral??
Now I have to wonder if the motor will fire once fuel is put to it, now prior to robbing the motor and controller off its prior home an ole tri hull, I had fired the motor and everything worked as I assumed it should, motor fired with shifter in neutral
