krakatoa
Thread starter- Joined
- Aug 8, 2008
- 705
Went back thru the thread so to restate where we started
4-blade 19 at 4100 rpm
now 3-blade 19 and your getting 3 different rpms (4400-4600-4800) at WOT so this tells me your trim is incorrect and/or your smart (dumb) tabs are causing some ventilation.
Tabs spring loaded of powered cause drag and lift at any position other then full up. As Maclin mentioned, in order to find the issue(s) we need to change one thing at a time.
Best way to find Max WOT with a prop, is place the tabs full up (or take them off) and place the cavitation plate flat an level with the keel. With both items flat and even we can get true numbers for slip.
The three diferents RPM was depending on trim position, so I spot the 45.6 mph around 4600 rpms. Wen I start this thread the boat cant do more than 4000-4100rpm. so now the following will be:
1 test the boat with no smart tabs and the 4blade prop, lets see what happen.....
maybe the tabs grab my missing 5 mph to reach 50mph, but not really sure cause the boat feels nice and free its not like dragging something.
