Mercarb 2 barrel TKS jet sizes?
WrenchNhammer
I didn’t realize there were different size jets when I broke my carb down for rebuild. The 2 barrel mercarb TKS goes on a 5.0 Mercruiser. Does anyone know which ones goes where?
Rick Stephens
There's three part numbers. Stock is #3302-9058. These are marked 1.65. Always run two identical jets in the 2 barrel Mercarb.
There is also a larger jet available to run richer - #3310-866283
There are only 2 jets installed, so probably one or the other. From what I can see the second number may be for the 5.7L motor.
Scott06
The two jets should be the same size left or right barrel doesn’t matter
WrenchNhammer
Not the one in the bottom of the bowl. I’m guessing the two larger ones go to the 2 barrels and the smaller one off to the side
Scott06
Yes this is outlined in chris chart. The smaller one is the enrichment jet for cold starting
WrenchNhammer
I think I got it straightened out thanks. So just so I understand, the enrichment is only used during cold start and the 2 main jets supply fuel on the regular?
WrenchNhammer
That’s what I’ve gathered. First boat I’ve had with a carb and I don’t care much for it. First I didn’t realize they were different sizes and put the enrichment jet in the other and it had me stumped lol
Scott06
Yes the enrichment valve basically replaces a choke system, to provide for richer fuel mixture when starting. Idea was since no one drives a carbed vehicle anymore and knows how to set the choke beore starting ... that you can just walk up trun the key and starting like injected engine...
Yes the main jets supply fuel during normal operation, the carb will run off the idle (mixture screw at carb base) and then transition circuts until there is enough airflow through the venturi to start siphoning gass out of the mains. I think this is normally about 1500-2000 rpm before the mains start dribbling fuel. Look down the bores while you advance the throttle you can see this happening.
nola mike
It's not like a secret handshake that nobody tells you about. If pumping the throttle twice is the hardest part of my day, that's a pretty good day.
Scott06
only if you have a beer in the other hand.... agreed its not that hard to figure out....
