toneybrown
Thread starter- Joined
- Jul 1, 2013
- 104
So, last summer I had this same issue. Stop the engine and fuel would drip down, then the boat didn't want to restart until all the fuel evaporated or I opened up the throttle to let it air out. Last summer I installed a new needle, seat and float. Adjusted everything and the flooding problem stopped.
Today I pulled the tarp off the boat, reinstalled the points and changed oil. Had a hard time getting the engine started, but some starter fluid seemed to work. I killed the engine and fuel was dripping into the carb at a much higher rate then when I had the issue last year. A very fast steady drip.
I pulled the carb off, checked the needle and seat. Readjusted the float to 14mm and 27mm drop. I am currently using the spring. As that is what was in it when I first tore it apart last year.
So, is there some other adjustment I need to make? Is the float adjustment I found incorrect? I measured from the bottom dot on the float to the rim of the carb.
Any help is appreciated.
