Mercarb rebuild kit
cooter2506
Im having some trouble locating a rebuild kit for my Mercarb. The numbers on the carb are as follows 861448 7703. It is on a 1998 5.0 2 barrel.
Acer2428
Re: Mercarb rebuild kit
Find out who makes the mercarb (holley, etc.)
and then you can find a rebuild kit on ebay.
95yj
If it's a Mercarb, it's made by Mercury. Rochester stopped making the 2bbl that Merc was putting on it's motors so Mercury designed their own. You can tell it's a Merc because the Rochester had two idle mixture screws whereas the Merc has only one.
There are two different rebuild kits depending on whether you have an older or newer style Merccarb. The difference is the accelerator pump. The older pump rod is straight and is cut off flat at the top. The newer has a 90 degree bend at the top. I would think being a 98 you have the newer carburator.
Older Mercarb Kit: 3302-804845
Newer Mercarb Kit: 3302-804844
When DonS gets in here, he'll probably be able to give you more specifics from your carb casting numbers.
thrasher
My 1991 mercarb 2brl had the later 90 degree bent fuel pump plunger, so its a very good bet that your 1998 will need the later kit with the bent fuel pump plunger
cooter2506
ok great guys that is the same ifo I found a little bit ago. I will order the newer version.
