Mercathode??
BigDog98
So I was told that every salt water boat needs a mercathode. I also heard that most boat's already come with the system. So my question would be, does a 1999 searay with a bravo 3 come with a mercathode? Or should it. If not then how hard is it to install? And is it truly a must have.
roffey
It will have a mercathode on the out drive. In fact there will be several. Is there a specific question you have?
BigDog98
It will have a mercathode on the out drive. In face there will be several. Is there a specific question you have?
Where do i find these mercathods and how do i test if it is operational?
roffey
Not sure when they started to install them but have been in use for a while, long before 1999. Mercathode is for Mercury and is an anode, used on a bunch of things, like water heaters, cars and big ships so they are not just salt water. They prevent corrosion and are really a sacrificial anode. Now that I have said all that, let the experts have at it, LOL.
roffey
They are on the out drive. If they look corroded then replace them. Give me a sec and I will post a pic.
roffey
check you messages, I sent you a PM. If you suspect they are bad or to corroded then replace them. Easy as it gets, screw on screw off.
JASinIL2006
Isn't the Mercathode a bit different than just the passive anode found on outdrives and in waterheaters? I believe the Mercathode system has an electronic controller in addition to the anodes. Google Mercathode and you'll find some good explanations of what the system is, and how it differs from ordinary anodes.
Fun Times
The bravo engine packages typically came standard with the MerCathode system, an active cathodic anti-corrosion system...So yes it should be there. Using the info below, look for either a blue or black box as they had both colors back then.
Mercathode
The Mercathode is a device that helps protect against Galvanic Corrosion. < More info you'll want to read BigDog98.
Most newer Mercruiser Engine Packages (with the exception of the 4 cylinder models) come standard with an installed Mercathode Antigalvanic Corrosion System.
The Mercathode system has two parts; the Controller and the Anode.
The Controller is located in the boat and it's usually mounted on the engine. The Controller sends a signal to the Anode which develops a protective field around the sterndrive unit to protect it against gal;vanic corrosion. It should be wired directly to the batteries positive terminal with the included in-line fuse. The Mercathode must stay powered up even if the battery switch is turned off.
There are four color coded wires attching to the Mercathode Controller. One is RED for positive power. Another wire is BLACK for a negative ground supply. One wire is ORANGE and yet another is BROWN. These ORANGE and BROWN wires run down to the Anode device on the bottom of the gimbal housing. The Anode is mounted outside the boat on the very bottom of the gimbal housing assembly. It is a black plastic device which is held in place with two bolts. The Anode is what produces the invisable protective field around the drive unit. The Anode must be kept clean and should never be painted.
The Mercathode will drain your boats batteries. The harder it has to work the faster the drain. If you are keeping your boat in the water you NEED to keep a battery charger on the battery or the battery will go dead and you could sink the boat. Make sure you use a marine rated fully regulated and fully rectified battery charger.
If you keep your boat in the water and you dont have a Mercathode, GET ONE. They are not too difficult to install and the whole Mercathode Kit is only about $119.00
Safety
Boats can explode. Moving parts can rip off your fingers. Hot exhaust can burn you to the bone and props can slice you up. One spark near a battery can cause an explosion. You can never be too careful. Remove the battery from the boat before working with fuel. Always disconnect the batteries negative terminal first. Clean up any spilt fuel and let ALL of the fumes dissipate before installing the battery and starting the motor. Pulleys and Belts can grab your clothes and hair. Don't wear loose clothing and keep your hair up under a hat. Always wear safety glasses. Be smart.
MerCathode System Wiring Diagram
a &#150; Controller
b &#150; 20 Amp Fuse
c &#150; Electrode
tpenfield
BD - Look for a electrical box on the engine that looks like this and says "Mercathode" on it :D
A 1999 Bravo 3 will have one as standard equipment.
It essentially puts a trickle charge of electricity (about 10 ma) into the water around the outdrive so that the stronger metals have a source of current (electrons) rather than taking electrons ( i.e. material) from the weaker metals. So those 2 big stainless props along with those big stainless counter rotation prop shafts won't eat the daylights out of the aluminum casing of the outdrive via galvanic corrosion.
You can also get the 'prop nut anode retrofit' kit for additional anode protection. As an added measure for my B3's I paint the bare props with "Cold Galvanizing Compound" so they have a direct source of weak metal.
If you keep the anodes on the outdrive fresh, make sure the Mercathode is working, and add the prop anode, you should be OK for a season on LI sound. Then you get to throw it all away and put on new stuff next year.
Chris1956
I had a Mercathode on my '88 SeaRay Alpha 1 outdrive. It had the controller on the starboard side of the motor and the cathode on the outdrive, replacing the center zinc anode. I had a SS prop and SS trim tabs on that boat. I put zinc anodes on the trim tabs, above the prop and on the trim cylinders. They would generally last 1 season or sometimes I needed to replace them during the season. There was no damage to the outdrive.
thumpar
My 1996 Bravo 1 has a Mercathode. The unit is in the box that is on the engine that has the serial numbers on it. You just lift the lid to access it.
BigDog98
What can i do to check if the mercathode is working before the boat goes in the water.
tpenfield
http://lmgtfy.com/?q=how+to+test+a+mercathode+system?
Click that link . . . :)
Most procedures call for testing the system when the boat is in the water (because that is what you are really testing for . . . You could do a basis test to see if the 'blue box' is getting power, while the boat is out of the water.
