MercCruiser 7.4 MPI (big block Chevy)
smhead
Does anyone have the manufacturers specs for cyl compression for the subject engine? Thanks
cooter2506
Re: MercCruiser 7.4 MPI (big block Chevy)
Check out the Adults Only section and download you manual. All info is in there.
Ayuh,... The Big Question is,... What did You get,..??
About anything over 100psi,+ it'll Run....
Depending on the Build,... 120psi to 180 psi is concieveable...
picklenjim
Cylinder compression ratio is 8:1.Cylinder pressure probably around 150-160lbs..All cylinders should be within 10% of each other.
smhead
I'm shaking down a 1998 Eliminator Eagle XP this Wed and will perform a compression test on all cyl prior to purchase.
