Re: Mercmonitor install on 2006 Sea Ray 260 Sundancer w/5.7MPI
84-879979T11 is for a 10 ft SC1000 System Tachometer Harness.
The Mercury SmartCraft System products are C.A.N. compatible. C.A.N. (Controller Area
Network) is a communication protocol which uses a pair of wires to transfer data between
components throughout the vessel.
This communication circuit is called a C.A.N. Bus. The C.A.N. Bus circuit must include 2
termination resistors and be installed as follows:
Wiring Installation Guidelines
TERMINATION RESISTOR PLACEMENT
WARNING
Correct installation and location of the Termination Resistors are critical for proper
system function. Improper installation may result in communication errors.
NOTE: Termination resistors are designed to reduce noise and provide proper DC voltage
levels on the C.A.N. Bus circuit.
1. Each system must include exactly two (2) termination resistors.
2. Termination resistors must be located at the furthest ends of the main C.A.N. Bus trunk.
3. The main C.A.N. Bus trunk may not exceed 36.6 m (120 ft.) in length (measured along
the cable). Main C.A.N. Bus Trunk is defined as the length of cable located between
There are three (3) acceptable methods of adding termination resistors to the system.
1. Junction box termination resistors.
2. Termination resistor inside the harness with a termination resistor at the junction box.
3. Termination resistor inside the harness at both ends.
NOTE: Junction box termination resistors are designed to plug directly into junction box
ports.
Harness Termination Resistor (One End)
Some of the SmartCraft wiring harnesses (84-879981T_) are designed with the termination
resistor at one end. Harness termination resistors are used primarily for installations which
do not require a junction box in the rear of the boat.
Harness Termination Resistor (Both Ends)
Harness (84-879982A20, 30) include termination resistors at both ends and may be used
to connect System Monitor or System tachometer directly to the engine without junction
boxes.
mjfink, Your harness part number 84-879979T11 appears to have no termination resistors at either end so you should technically speaking have had some type of junction boxes with two termination resistors or a harness with up to two termination resistors somewhere else inline as the manual i'm looking at shows tachometer harness (84-879979T11) going into two junction boxes with somekind of termination resistors inline between the engine and gauge.
You can only use two junction boxes with two termination resistors or two termination resistors already in the wire harness, or one already in the harness and one pluged into the junction box.
I see you got it going, Good job.
