I recently bought a boat with a 1976 Mercury 65hp. The jackets on the throttle and shift cables were damaged and rusting so I've purchased some new ones to replace them.
I was able to get the MerControl box open easy enough to remove the old cables and attach the new ones, but now I'm having an issue that I believe might have to do with the alignment of the cam roller on re-assembly. I kept playing with the position of the roller until I could get the unit closed, but the throttle activity is not what I would expect.
1. The throttle cable seems to bind a bit if the warm up lever is pushed all the way down in the locked position.
2. If I push the throttle forward it does go in to gear but the throttle cable does not seem to engage until I push the lever to about half of the total throw.
3. If I push the throttle in reverse it seems to go in to gear and the throttle cable begins to react almost immediately if I continue to move the lever further in reverse.
I'm new to this and any suggestions or tips on how to get this configured correctly would be greatly appreciated.
Thanks!
Jake
Thanks!
Jake
