Mercontrol question.............
Mbrgr1
Hello all, is it possible to adjust the levers on this set up to position the beginning neutral point?
In other words, I'd like the levers to be closer to the dash to start, I really don't need WOT for reverse, they are in an uncomfortable position for forward operation. Thanks
achris
More fish than mountain goat
Re: Mercontrol question.............
Yes it is, but involves pulling the controls apart and putting the handle on one (or two) splines different....
Bt Doctur
not so much apart but move them to wot and you`ll see a set screw ,loosen it and remove the black neutral button, it just pulls out.
return the handels to neutral position, slide handels off and reposition to where you want them.move handels to where you can tighten the setscrew, pop neutral button back in.
Mbrgr1
Thanks! I'll give it a try. MK
