mercruiser 110 swap
1966starcraft18ft
So, i am still having ignition issues on my 1966 starcraft. Model is a holiday i believe.it has a mercruier 110/mc-1 i/0.
Anyways, i was in the boat trying to figure it out and my other half goes " can you just replace the motor?" to which I replied " oh god yes".
So, with that being said, i've been eyeing a 3.0/alpha swap. I've read the 3.0's are like 140 hp. all documentation i have seen states that my boat is rated for 120 hp max. My question is, can this be done without ripping out my brand new floor and reinforcing the hull???
dozerII
I don't see any problem at all they are virtually the same motor only updated with a little bigger bore. The same hull was released 4 years later with a 120/140. I say go for it. Do you have a line on a complete donor boat? You will need everything as the trim and tilt and shifter will be different.
1966starcraft18ft
not yet. gathering info before i take the dive into it. is the 3.0 the only viable option without re-engineering the hull?
dozerII
Anything other than the 3liter will be bigger with considerable more hp, that being said!! Watermann did put a 205HP 4.3LX V6 Mercruiser in is 18 Chieftain that is rated for 120 hp:D
