Greetings,
I'll try to be succinct. Working on a Merc 120 Hp (3849449) thought to be a 1975. When I try to start (it's out of the boat on a pallet) she cranks and wants to fire and then I get a *POP*. The popping noise seems to come from the carb and I even got traces of smoke, guess it could have been steam.
Here's a little history:
Had the head off as well as the distributor so timing could be equated, but I feel confident that I located TDC
I am also reusing the head gasket, it calls for the bi-metal gasket and it looked good, figured no harm to reuse. (I realize that buying a new one is the best practice)
The most likely problem, although many told me this would work, I am using (trying to use) the exhaust manifold off a Merc 140 (2800770) also thought to be a 1975 but unless I am mistaken that is impossible by that model #. There is obvious variances between the two manifolds, but from visual inspection it did appear to be fundamentally the same.
Thanks for your help, it's appreciated. If I can add any info to help you remotely diagnose my issue let me know and I'd be happy to update.
Cheers
Cheers
