ispurpleafruit
Thread starter- Joined
- Dec 26, 2007
- 14
I have a 1967 Chrysler courier with a 120hp mercruiser engine. I have been having problems getting the boat out of gear. someone told me about something called a shift interrupter switch. I adjusted the linkage to properly actuate the switch and it worked great for a couple of times out on the water but then it started happening again. When I run the boat off the hose and try to activate the switch by hand it doesn't do anything. So i put a continuity tester across the terminals and depressed the switch and sure enough the switch works just fine. Does any one know where the switch ties into my ignition system so I can look there for a problem. If anyone has any input at all it would be greatly appreciated. Thanks Andrew
