Mercruiser 120 Water in Oil Mercruiser - FelPro - Sierra Gaskets
mlackore
I have a Mercruiser 2.5L (AKA 120) 1984 model with water contamination in the engine oil. I have gone through the standard, emergency motor-saving steps.
Considering the rough idle this boat exhibits, I suspect a head gasket, cracked head, or cracked block. I have a couple of questions before I dig in.
First question: In preparation for the project, I am shopping for some gaskets. What are some opinions regarding the Fel-Pro, Sierra, OEM, or other gaskets?
Second question: Before I proceed to dig deep into this old iron duke, I plan to do a compression test. Will this positively diagnose whether I have a cracked head, block or blown head gasket?
Thanks guys.
Re: Mercruiser 120 Water in Oil Mercruiser - FelPro - Sierra Gaskets
Ayuh,... It ain't an Iron Duke....
That's a 2.5l Pontiac based corporate motor,... Used by alota Hot Rodders...
Yer's is a Chevy...
A compression test will tell ya if the headgasket is gone,...
A cooling passage pressure test usually shows ya where the cracks are...
