Mercruiser 120
Cranks but wont start, it's shooting fuel out of the carb, out of the engine compartment, with the flame arrestor off, any suggestions.
HT32BSX115
Re: Mercruiser 120
Yeah. Get yourself a rebuild kit and rebuild it. (the carb)
brntrt
Re: Mercruiser 120
Hey Rodeo, are you sayin that fuel is coming out the top of the carb and shooting up when you have the flame arrestor off??? If so you should do a compression test, you may have a stuck valve or two, or maybe a burnt valve. Sounds like the compression from one or more jugs is pushing back out the intake.
Re: Mercruiser 120
With the flame arrestor off and cranking the motor fuel is coming out of the needle? looks like a straw that goes down into? about a 45 degree angle coming out of the top of the carb, and its a pretty fair amount of fuel too.
Any ideas on what the carb kit part # is so I can order from iboats? Or the SC part # to cross reference?
crewscontrol
Re: Mercruiser 120
Everything you need to know about the carb and the re-build kit is on the little metal tag under one of the screws that hold the top of the carb onto the bottom of the carb.
Re: Mercruiser 120
And I wish that little tag was there, but unfortunately there is only the corner of it left under one of the screws.
Re: Mercruiser 120
Ayuh,... There'll be a name or numbers cast into the carb casting,...
Look it over Closely....
Silvertip
Re: Mercruiser 120
If this is a Rochester 2 barrel carb, and you just purchased the boat -- someone may have attempted a rebuild and didn't notice a check ball. Failure to reinstall the check ball (if the carb had one) causes this issue.
woosterken
Re: Mercruiser 120
rodeo, you dont say what year you have but the tag on my 1974 120hp
says GM rochester - 2 jet
serial # 1351-5202A1
woosterken
