nearpar
Thread starter- Joined
- Sep 4, 2010
- 143
I purchased a boat with a mercruiser 120 it seems to run great. However I changed the oil it was all milky. Compression is good on all cylinders. The only thing I did notice was some steam commingl out of the number 3 spark plug hole when I removed the plug. Is this a cause for concern? Where would I look for the problem? Cracked block? Cracked head? Head gasket? Manifold? .......help!
Thank you in advance.
