Mercruiser 140 lash pusher rod setting?
TravisP32
Hi, I put a new head on my 140. I set up the backlash properly but I noticed one push rod I can move up and down fairly easy. I can grab the rocker arm and push down on the lifter and feel the spring tension, but its easy to move like I mentioned. All the other ones can't be moved that easy. Do I have a lifter problem. I've had the engine running a few times with the valve cover off. Its been awhile since I have had to set valves up. can someone give me some advise on that one lifter. I'm guessing I will need to change lifters. Thanks for any help you can give me before I start taking out lifters.
JustJason
Re: Mercruiser 140 lash pusher rod setting?
Run the engine for a few minutes so the lifters are primed then redo the procedure... you missed something.
TravisP32
Thanks I'll try it again.
TravisP32
Thanks, That seemed to work. It just must have leaked down.
