nrasnake
Thread starter- Joined
- Aug 13, 2012
- 62
Below is a picture of my exhaust manifold on my 1985(?) 3.0L (SN 6891354). Is the piece on top with the bolts sticking out of it a spacer? Is this original? If not, what would be it's purpose?
I cracked into all this today and based on the amount of rust in this "spacer", the riser (elbow - not shown), and the end of the manifold... I'm planning on replacing everything, but I'm not finding the spacer (that looks like the one I have now) anywhere. Can anyone shed some light on this for me please?
For laughs, any reason I shouldn't replace everything? Is the severity of the rust suggesting a definite replacement? I bought the boat two winters ago and was told it sat for 3-4 years. I did have it running last summer before I started my transom overhaul. It seemed to run fine, but did eventually started to creep up on 180 degrees or so after about 10 minutes and I shut it off. I assumed at the time it likely needed a thermostat and that was the cause of getting hot. I did just replaced the thermostat and there was some significant rust in the housing. It seems now my problems could be worse.
One of the ports in the "spacer":
Manifold end with plate removed:
Thanks!
Thanks!
