Re: mercruiser 140 runs rough at high rpms
I can double check your numbers....
1. what is your timing set at, both idle and full advance?
2. what is your dwell set at?
3. when was the last time you changed your fuel filters?
4. have you checked for water in your fuel yet,
5. how exactly did you "rebuild" the carb
Personally that is where i would start... However your problem definitely lays in here:
Engine Won't Reach Operating RPM. Check
• Fuel condition. Type and Octane possibly old fuel
• Propeller pitch or diameter, damaged blades
• Restricted fuel pickup tube or anti siphon valve Fuel System Test
• Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
• Marine growth on hull and outdrive
• Wrong gear ratio in outdrive
• Restricted carburetor air intake (clogged flame arrestor)
• Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
• Poor cylinder compression Compression Test
• Carburetor defective, or wrong type.
• Fuel pump pressure and vacuum
• Boat overloaded, improperly loaded, or improperly trimmed.
• Engine Overheating
• Engine timing and ignition system operation (Full tuneup done recently)
• Remote control cables and linkage for proper travel to open throttle plates fully.
