Mercruiser 140 stalls when I shift into reverse
Al Bell
I recently purchased a Glastron Carlson with a Mercruiser 140 inboard and Alpha one 165 outdrive. The boat runs great forward, but when I attempt to put it in REVERSE it stalls. I was told that it might be the shift interrupt switch. Does anyone have any advice on what the problem might be?
Don S
Re: Mercruiser 140 stalls when I shift into reverse
The shift interrupt switch is working fine, that's why it stalls. The problem is most likely a rusted and corroded stiff moving lower shift cable. You can download an OEM service manual here.
http://forums.iboats.com/showthread.php?t=251571
Al Bell
Thanks for the links. I noticed that one of the cables from the shifter was not secured properly along with the other cables ( cable had fallen down along the gunnel). Would that be the cause of my problem?
chiefalen
One of the ties broke that hold it up?
Nope that's not the problem.
The shifter from the helm moves a converter that moves the lower shift cable that goes to the out drive.
Don just told you it's the lower shift cable.
If i were you i would believe him.
A lot of people think they can adjust it, may work once or twice but its toast probably need a new one.
Haut Medoc
Replace the lower cable.......;)
180shabah
Replace the cable now, or wait till memorial day weekend to do it instead of enjoying you boat with friends and family.
Ayuh,....
It's No Doubt the Lower Shift Cable needs replacing at least....
It's also got the Wrong drive on it,....
That drive is geared for a I-6 motor,.....
The 140hp uses a 1.98:1 ratio,....
The 165s were I believe a 1.84:1 ratio, maybe 1.65:1...
Btw,.... It's Not an Alpha 1 either,.... It's a Mod. 1, or Pre-Alpha drive....
Al Bell
Bond-o,
What effect does the change in the drive ratio have in the overall performance/operation of the vessel. It currently has a 21" pitch aluminum prop and has a wot of 4700 rpm with full fuel and 2 adults.
Also, do you have any idea of what I should be paying to have the lower shift cable replaced?
Ayuh,...
It would Appear, that the gears may have been changed in the drive, if you can pull a 21" prop with that load....
As for what it might cost to have somebody replace the cable for you,...
I really don't know...
I do most of my own work,+ barter with Buds to get done what I don't do.....
Al Bell
$510 dollars later my initial problem is solved but now I am having difficutly shifting in an out of gear (it does not shift out smoothly). I thought it was the idle to high but it appears the gears may be the issue. Any advice? Keep in mind the drive is not the original.
chiefalen
You should be between 650-700 rpm at idle in gear on the water.
Don S
Please explain.
They do not shift like a car. There is some resistance, that's how they work.
But you could also have a faulty shifter unit, or a bad cable between the shifter and the engine. YOU, have to know what is right and what is wrong. Sorry, but we can't feel how it shifts.
