I have a 1982 Sea Ray with a Mercruiser 140 I/O, engine SN 6045398 and outdrive SN 6039139. With light use in fresh water and regular maintenance, I have had no serious problems until now.
The engine developed a knocking sound and I only ran it a few minutes to get back to the dock and it had good oil pressure while it ran. I started it again and pulled each plug lead to see if it was a rod or pin noise but no change. It then stalled and when I cranked it over, it went a few turns before locking up. The cylinders were full of water, it had no compression when tested (after draining the water) and the distributor rotor is about 20 degrees retarded from where it should be. Conclusion is that the timing gears are out of mesh and maybe the knocking noise was caused by that.
I am planning to pull the timing cover off and see what I have. If I am lucky, the damage will be confined to one or both gears and not have damaged the keyway on either shaft. If I am not so lucky, I guess the engine will have to come out for a complete replacement or rebuild.
Assuming I get that far, I have looked at the procedures in the manual for replacing the vibration damper and read a number of earlier posts on this forum about the procedures for doing so. My engine does not appear to have a threaded bore in the center of the crankshaft. The manual I have is for a later 3.0 version of this engine and it shows a tool for installing the damper that threads into the center of the crank. However it also says an alternative method is to tap it on using a block of wood.
A number of posts I have read say the best way to avoid damage to the thrust bearing is to remove the engine. Does that mean that you need to put the entire engine block with the crank installed in a press? If you use the block of wood method and clean up the crank and damper bore carefully, can you avoid damaging the thrust bearing?
Appreciate any advice anyone can offer
