- Joined
- Apr 17, 2002
- 71,464
Re: Mercruiser 165 questions
Ayuh,...
You run a pretty good chance of Over-reving the motor,+ probably won't have good top-end speeds...
Unless on the outside chance you can find a prop Big enough to make up the difference....
So What would happen if I was to run this combo, if the the gear ratio is 1.98:1?.
Ayuh,...
