I switched out a bad exhaust elbow for a newer one that I have. The difference is that my engine is setup for "reverse flow" on the coolant line, so I need to put a 1" MPT x 1" hose
fitting into one of the pipe plugs on the new riser elbow. The pipe plug is not cooperating.
Wouldn't budge, so I put a 9/16 square drive into the plug and used a small air hammer.
The edges of the plug mostly fell apart, but the plug didn't budge. I thought it might
come out without too much trouble because there is teflon tape on the plug.
Anyway, if I can't figure out how to remove it I will probably remove the riser and take it
to a machine shop. Has anyone successfully removed these plugs? Maybe drill it out
with a 1/2 or 9/16 and then a big screw extractor? Didn't know if a little heat from a
torch will help or hurt. Thanks for your ideas!
