Mercruiser 170 Choke & Ignition Voltage Problem
TBB
I recently replaced the breaker points and coil on my Mercruiser 170 with a Pertronix Ignitor and Flamethrower coil. In the process of circumventing the ballast resistor for the old coil, I discovered that the electric carburetor choke is robbing the ignition system of voltage.
The ignition wire from the key switch only shows 9 volts with the key switch on. However, if I remove the ignition wire connection to the electric choke, the voltage pops right up to 12 volts. Both the dash voltmeter and a hand-held meter confirm this.
Is this normal? What is the likely culprit and fix?
1986 Searay Seville / 170 3.7L Mercruiser
