jordache16
Thread starter- Joined
- Jul 21, 2012
- 19
I have an '82 Century Sport 2000 with a Mercruiser 228 (pre-alpha type 'R' I believe) and am looking into replacing all the bellows on the outdrive. Just a little background, I bought the boat a year and a half ago with a frozen block so I had the engine out last Winter to rebuild it with a new block (this is a family boat so I know much of its history and there is some sentimental value there, otherwise I wouldn't have messed with it). I knew she took on water when I bought it and when I pulled the engine I found that both exhaust elbows (I think that is what they are called) were almost completely disconnected from the Y-pipe. Well that was one major leak that I fixed but last Summer after getting everything back together I found that she was still taking on a little bit of water so finding/fixing the leak has been on my winter todo list. The few times I left her out on the water over night there would be a few gallons or more to pump out the next morning (I didn't sleep very well those few nights that I had to leave her on the dock knowing that she leaked).
Well a couple weeks ago I got around to filling her up with water, just hoping that it wasn't the Y-pipe again. I was fairly confident that it wasn't the Y-pipe but really wasn't sure what else it could have been. It took quite a bit of water before I finally found out where the leak was coming from. The water level got up to above the bottom of the oil pan, well above where the Y-pipe connection was so that made me feel a little better but it still wasn't leaking anywhere. I was about ready to turn off the water and that's when I noticed it was starting to leak out somewhere. When I pin pointed where it was coming from I thought, "duh, that makes sense... the shift cable bellow". The shift cable bellow was pretty cracked and beat up, I wouldn't be surprised if was the original. I didn't even think of replacing all the bellows last Winter when I had everything apart. So good news is, I found the leak, but now I have to tear the outdrive off again.
Well I went ahead and ordered a whole new bellows kit for the outdrive; u-joint, exhaust, and shift cable bellow but this leads me to my questions. I decided not to order a gimble bearing (not just yet anyways) as I wan't to inspect the existing one to determine whether or not it needs replaced. So first question is how exactly do I go about checking to see if the current gimble bearing is OK? Do you basically just check for any play and make sure it spins freely?
Second question is, can anyone here who has replaced the bellows on this type of outdrive before comment on how difficult of a job this is and/or possibly provide any tips? This will be my first time replacing the bellows so I am not sure what to expect. Also, is there anything else I should look for and/or replace (aside the gimble bearing) while I have everything off?
Thanks in advance.
Thanks in advance.
