chrismurr1
Thread starter- Joined
- Jan 27, 2011
- 41
Hi all, need your expertise again. My starboard engine wont exceed 3k rpm. here are the details.
1984 Merc 230 (305). new quadrajet carb (if you read my idle post a few months back...yes i got it tuned out and its happy from what i can tell). new mallory marine MBI distributor, bosch platinum 4 plugs and wires. timing 8 degrees BTDC @ 750 RPM. max advance on the dist is 24 Degrees (same as the TB IV ignition on the port side).
fires up cold without issue, just hit the key and your gold. after getting out to the no wake zone i can take her quite easily to 2500 rpm and it can run all day like that. when i try to take it to 3000 it will go there and i can run like that for like maybe 30 minutes before i start to loose rpm. when i try to take it up to 3500 rpm (that will put me on plane without the trim tabs). it will burst to 3200 and drop back to 3000 then no matter how much throttle i give it (all the way to WOT) it just stays at 3000 and after a few moments will start to loose rpms.
now a few months back, i had this engine up to 4k rpm and cruising and that same day i lost my distributors pickup and fuel pump (that was with the original TB IV ignition at the time). it hasn't run that well since. I have since replaced the fuel pump and obviously the ignition system (last week the ignition amp went out and took the coil with it, it was far less expensive to put the mallory system in than replace the amp and i like the all inclusive design of the mallory, had it on my last boat and never a hiccup).
the only thought i had but have not tested yet is..... possible that the Platinum 4 plugs arent sufficient enough?
you help would be greatly appreciated. i have put about 400 into replacing parts and i still cant get her where she needs to be and the king mack fishing is almost gone......
chris
chris
