Blueghost924
Thread starter- Joined
- Sep 19, 2013
- 250
Hi, I recently bought a 1986 Regal Ambassador with the Mercruiser 260 V8 5.7L with the Alpha I / Gen I sterndrive. The previous owner took very good care of the engine, but apparently did not know about or keep up with sterndrive and bellows maintenance. We tried to start the engine and it wouldn't turn over a bit. After removing the sterndrive, the motor turned over great and started up and ran like a top. When we removed the sterndrive, the ujoint bellows had slimy gunk and whitish jelly in the bottom and was wet. Even more disturbing is that the sterndrive u-joints are rusted bad, and the drive is locked up. It's won't turn at all by hand.
I have a spare sterndrive in great shape that's been rebuilt recently by a marina (I purchased it from) with a 1:65 ratio that I was thinking about using temporarily. In looking at the Mercruiser tables, looks like the 1986 Mercruiser 260 5.7L used a sterndrive gear ratio of 1.50.
Couple of thoughts. First, for the locked up sterndrive - I'm thinking that it may be a waste of time trying to soak the locked up sterndrive in PB Blaster to see if it will turn...and I really need to start taking it apart. Second, in using my spare 1.65 ratio sterndrive, I'm going to have to re-prop to account for the higher gear ratio.
Comments or advice?
Comments or advice?
