OhSnap
- Joined
- May 4, 2010
- 77
Re: Mercruiser 260 HP OVERHEATING - Im Stumped!
From what I can remember, the plugs were tan colored. I did look at them when I took them out last year and dont remember seeing anything abnormal. I did however blow out the electrode from the porcelain and the porcelain itself right out of the metal threaded housing last year (all at the same time). Thats when I replaced all the plugs. All the other plugs looked good. I have no clue what caused that. At first I thought it was a lean condition but never happened again and all the other plugs were ok.
That incident also blew the belts right off the motor.
Just a thought from Meredith Neck. Could the motor be running too lean? That will over heat a motor also. Carb jets could be gummed up. It won't be your idle mixture screws. Are your plugs whiteish instead of tannish?
