Haut Medoc
- Joined
- Jun 29, 2004
- 10,645
Re: mercruiser 260 no power
Since you have a v8, the wrong drive ratio does not apply to you.....
Here are some other causes & tests for low WOT.....TB IV does not need to be placed in base timing mode.
- Fuel condition. Type and Octane possibly old fuel
- Propeller pitch or diameter, damaged blades
- Restricted fuel pickup tube or anti siphon valve Fuel System Test
- Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
- Marine growth on hull and outdrive
- Wrong gear ratio in outdrive
- Restricted carburetor air intake (clogged flame arrestor)
- Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
- Poor cylinder compression Compression Test
- Carburetor defective, or wrong type.
- Fuel pump pressure and vacuum
- Boat overloaded, improperly loaded, or improperly trimmed.
- Engine Overheating
- Engine timing and ignition system operation
- Remote control cables and linkage for proper travel to open throttle plates fully.
