Overkill82k5
Thread starter- Joined
- Jul 29, 2009
- 78
Re: Mercruiser 260 rebuilt - Water in cylinders and oil?
I did reference the manual...
I put the heads back on this morning and also the intake. I did seal the head bolts this time even though they werent the problem originally. I loosened all the rockers to keep the valves from opening so I could pressurize the cooling system and see it the intake manifold, oil pan, and/or cylinders would collect water.
With the exhaust manifolds loose (cold) and the system pressurized I have water running out of the #2 exhaust port. I dont seem to be getting any water in the oil pan anymore or in any of the cylinders. At first glance it appears as though I have a head cracked in the water jacket. It is probably the one that originally had the exploded valve in it, and the crack probably caused the hot valve to go boom.... I guess thats good news and not-so-good news all at the same time...
I am still going to keep checking with longer term tests to make sure thats the only problem. I have a gut feeling that at least one more is going to rear it's ugly head within the day, but we will see... Keep your fingers crossed for me...
Try the Mercruiser maintenance manual, works wonders.
