Chemdawg
Thread starter- Joined
- Aug 31, 2013
- 112
Hello everyone. I have a 1987 Arrow Glass Carisma 185 with the mercruiser 3.0/Alpha 1 combo. Engine #B523519. After dealing with my fuel and spark issues, and rebuilding the lower water pump/impeller assembly, I finally got everything running using my rabbit ears. Motor ran great. Took it out to the lake, and it ran well at about 40 mph/4500 RPM. Today I went to check the oil, and noticed the light solid tan color. Kinda milky. Oil isn't over full, so I know if it's some water in there, it's DEFINATELY not pumping it in big time. Pulled each plug out one at a time, and checked compression. On the plug side going from front to rear of motor:
1: 110
2: 80
3: 80
4: 110
Now i'm no boat expert, and am very new to this, but with my experience with car engines, and hotrods, that tells me that I have a blown head gasket.
I'm not for certain... Just my observation. Now I don't have the equipment to do a leak down test to each cylinder, so I did not try that.
In the beginning, once I got the fuel/spark issues handled, and got it running, I noticed it was over heating. Didn't let it run but for a few seconds once it got hot. I replaced all the impeller parts, and upper tube portion of the impeller. I also replaced the stuck open thermostat. After that, there was NO over heating. Ran very well.
Does this sound like a head gasket?
1: 110
2: 80
3: 80
4: 110
