I have a 1990 alpha 1 mercruiser 3.0 in my rinker 180...it acts like it's only getting half throttle...will eventually get on plane when by myself, but when i tow even my 80 lb daughter on a wake board, it doesn't have enough power to get up on a plane. carb has been rebuilt. fuel/water filter seperater installed, electronic ignition installed, new plugs, octane boost, fuel stabil. clean fuel...it starts and idles just fine. no hesitation upon acceleration...just never seems to get full power...checked for cable adjustment on carb. it's giving full throttle. any ideas? fuel pump? going to check fuel pressure...not using oil, and oil is clean as a whistle...
If i keep having problems, I'm thinking of just going to a bigger motor. Is there a bigger motor that will mate to the out drive? what motor change would be the best besides going back to low power at best... thank you....signed frustrated...I'm only using the boat for skiing and wake boarding and cruising with family
Edit/Delete Message
Edit/Delete Message
