Mercruiser 3.0 bogs when I hammer the throttle
Michael331
When towing a skier, my engine bogs significantly if I hammer the throttle from idle to full. I've always been able to pop a skier out this way on other boats but now that I own my own boat, the only way I can get on plane is by easing the throttle up. Is this a relatively common problem that I can solve with some carb cleaner, or do I need to do some heavy maintenance? My engine year is 1987 and everything is stock except a new alternator. The carb is a two barrel.
mkast
Re: Mercruiser 3.0 bogs when I hammer the throttle
When was the last time the engine was tuned up?
sarantis
I think it's a fuel delivery issue.Try an external tank directly to the pump.It may give you directly the answer .
Michael331
The engine was tuned up with it's summerization back in April.
Michael331
What kind of maintenance is involved with the accelerator pump? Is this relatively easy or really involved?
