Hi, I am installing my main bearings and I am not sure wich way the lower bearing halves supposed to be.. Should the "shoulders" be at same side or opposite sides with the upper side bearing halves? The bearing brackets have an arrow and I think the arrow should be pointing to the nr. 1 cylinder. Then the shoulders are at same side, but in the rear bearing the shoulders are opposite sides, and this bracket can't be installed wrong because it has the rear seal.
PLS HELP!
PLS HELP!
